Sony xm-7547
this amp has an offset fault. I have all the bias pots turned counterclockwise. When I disable the offset protection and check the test points 3 out of the 4 are ove r the .04-.05mv without adjusting the pots at all. The rages are from .06 to .09mv. I have a working 2 channel version of this amp I can reference from i just dont know where to start.
Where is the low voltage supply?
