Sony VFET using SK60/SJ18 - Load Question
Joined 2014
I have a Sony VFET built using the boards from the Store. I'm using SK60/SJ18 instead of the originals. Bias is .5A (half the amount of the original version). All is well and it's been working fine for about a year. It runs extremely cool. I've read a couple times that the K60/J18 like a 16 ohm load better. Most recently Nelson mentions this in the article for the upcoming VFET kits for this who already have VFETS. Should I consider some sort of modification to this amp to take advantage of this load characteristic?
mu follower is main ingredient of new ones
taking ( as Pa said) 40% of work, it fools VFet of thinking that there is just half of load on it
now - either tweak existing circuit to that, or hop to Store for new pcbs
don't forget that PSU for this iteration is 36V and that Iq is in range of 1V2/0R94
you can alter that some, but not much, sweet spot etc.
Thanks for that information. I think I will try both suggestions. I'll get one of the new "VFET-les" kits and also see if I can modify the original push/pull circuit without ruining my Sony transistors.
It seems that modifying the original circuit might not be simple because of the power supply differences, but I need to spend some time pondering it.
Cheers.
Thanks for this information. I certainly don't want to screw up the PP version. It's pleasant sounding, albeit I like the Aleph J (SemiSouth version) a bit better. I do have a set of K60 remaining so I'll order a kit from the Store when they are available.
Maybe this is an excuse to purchase a set of efficient 16 ohm speakers... (any suggestions?)
I bought the new card 🙂 and have the 2SJ28.
Preparing:
  1. I need to change a bit the output-node/source resistor divider. Original for 2sj28 is 1,5//1.5ohm=0,75 ohm; new for 2sj18 is 0,5+0,5 ohm = 1 ohm total. So I need to lift the output, and insert the two 0,5 ohm resistors, and connect the output to the node in between. There will not be such a hole on the card probably.
  2. The 50k setting pot will work as well as the 25k trimmer.
Hope that is all . . .
redo after coffee helped me think:😕
Preparing:
  1. I need to change a bit the output-node/source resistor divider. Original for 2sj28 is 1,5//1.5ohm=0,75 ohm in one step (=pure CCS); new for 2sj18 is 0,5+0,5 ohm = 1 ohm total (=a MUfollower). So I need to linsert resistances in a different way, and insert the two 1,5 ohm resistors in parallel, and connect the output to the node in between with a short in the second hole. Then I have a CCS again.
  2. The 50k setting pot will work as good as the original 25k trimmer in the 2SJ28 design from last year.
  3. As my speaker is 6 ohms (mostly above 500Hz, because of shunted filter) might still need something in between, say 0,68 and 0,12 ohm or so, to still trick the 2SJ28 SIT into a thinking a higher load. Then I have a little bit of MuFollower; I can experiment a very little bit but lately I am not as effective any more. I have an analogue distortion meter.
