Sony vFET Amplifier Part 2
Really?
I still can't find the "latest" version of the original schematics (Was it updated since the original VFET2 pdf?), but if the differences between GB and Original are only things Nelson explained on the newest pdf, I though it's not too hard to utilize GB board as a basis of the original version...
I also was wondering what is the best way to deal with the extra pairs of VFET, which probably would require extra L-bar.
There is no cascode feedback, no provision for the global feedback switch, no bootstraping in the output mosfets so quite a few differences. It is doable certainly but not for the faint of heart!
Some members have developed boards for the original version.
Sorry but what we can put for the 2SK2013/J313 ??
Possible FQP3N30, FQP3P20 as other Firstwatt amps. I know one USA supplier who claims to have orginal 2SK2013/J13's but as always with these obsolete parts I am somewhat skeptical unless they are tested.
From the Firstwatt BA3 build,
The 2SJ313 and 2SK2013 are still available, and you can use them or substitute other Mosfets, such as the Fairchild FQP3N30 and FQP3P20. The Vgs of the Toshibas is about 2 volts. Some of the alternatives will be in the region of 4 volts or so, requiring a higher value for P1 and P2, probably 1K ohm.
http://www.diyaudio.com/forums/diyaudio-com-articles/194809-burning-amplifier-ba-3-a.html
I will wait to read Jim's build instructions to find out what he used.
So - thanks to Nelson and the DIY-Audio-Team quite a few of us will get their hands on 4 pairs of V-Fets.
What should we do, build 2 pairs of the "The DIY Sony VFET" or use the FETs to build the original 2015 "VFET Part 2" Amp? 🙂
The PCB which is provided for, only supports two VFET's, one pair.
So if you want to do the original 2015 VFET pt2 you have to look for different PCB supporting two pairs.
I'd like to post a response to a question asked over email. The question being "What happens if I fry my VFETs?".
We haven't discussed it, but several items:
1) The design is conservative, and the initial testing procedure is
intended to catch issues and make adjustments before the VFETs get
installed.
2) I have pre-tested and measured the kit VFETs at power.
3) They are quite robust. I have not lost a single device in spite of the
usual mishaps on the bench and in the field.
4) An allowance has been made for a percentage of failed parts. Policy
for providing replacements has not been determined.
5) When all the VFETs are dead and gone, I have a procedure for
replacing them with ordinary Mosfets.
