Sony tava 777es pre outs
I'm not sure this is the right forum but after all my sony is a solid state amp ;-).
Taking a look to the service manual,http://techneaux.mine.nu:81/~mobetta/Images/Sony777es/servicemanual.pdf,I found that the signal of the pre outs are taken from the power amp outputs(!), as you can see on the block diagram on page 10.Do you think I can get the preouts directly from the out of the opamps NJM2114 on volume board section, page 39,or the signal will be too low?
Thanks.
Marco
