SONY TA-FE530R schematics needed...
Re: TA-FE530R supply
alexclaire said:
thanks for your reply,
I try to find this schematics because i'm gonna buy this amplifier on ebay (psu problem).
Presumably it's advertised as having a PSU problem?, but is the seller informed enough to know? - I would have thought it's more likely a power amplifier fault?.
However, Sony's do have unreliability problems with mains transformers, because they tend to buy cheap chinese ones which are often too small for the job. As it has two windings you would probably need two transformers to replace it, or buy the correct one as a spare - but they are STUPIDLY expensive from Sony (this assumes the transformer is faulty of course!).
sony psu problem
Yes you're right,
maybe the seller pointed the wrong direction.
By the way, i'm gonna replace the power stage (2*stk modules) by 2 hexfet power stage rated at 100WRMS/4 ohms.
The main transformer will be replaced by a toroid one.
From a TA-FE520R
Hope this helps
regards
James
