Sony TA-F770ES output replacement
I'd stick to something with a little higher Ft like a KSC2690 or TTC011B but I haven't tested them in this location.
I think I used a piece of double sided tape and stacked some foam on top to keep pressure on from the botton grill but I don't think I would do it this way today. Maybe some kind of two part glue (don't know how this is called in english, like a resine and a hardener you mix together) or even better drill two wholes and tap them.
