Sony TA-F6B PLPS repair
Hi!
I'm restoring an F6B(European model), the power supply kicked out the bucket. A cap at the regulator part blown up(C604), killed some transistors around it.
Already replaced all caps, measured all transistors, I still have to check all resistors and diodes(but at first look they seems to be fine).
The original 2SC2023-Os at the inverter are fine, also Q605, Q606, Q607, Q608 are ok.
The problem in the regulator part is with an R grade 2SC2023 (Q613), 2SC1810 (Q602), 2SA911 (Q603). I suspect that I should change all transistors in the regulator, at least Q601/Q613 to the same.
I have a few 2SC2023 (without R or O) but still doesn't find any info about the lettered versions, so don't know whats the difference and why it is only R type allowed in the regulator and R or O at the inverter. Also if I change 601/613 to simple 2023, would it affect the other part of the power supply?(sadly I don't have that kind of deep knowledge about electroics or SMPS/PLPS)
Found some old datasheet for 2SC1810 but nothing for 2SA911.
It would be a really big help if someone could advice some replacements for 2SC2023R, 2SC1810, 2SA911. Maybe I could get some new old stock from the last two from eBay, but I would prefer some common off the shelf part.
I know there was a thread a long-long time ago with similar topic, but exact working replacement parts wasn't clear at the end.
Attached the schematic from the service manual, marked the bad transistors.
