Sony ta-f690es burnt out resistors
I have a sony ta f690es its stuck in protection mode r367 and r368 look burnt out anyone with experience with these amps know will changing these 2 fusible resistors fix it or will there be more damage?
The service manual can be down loaded from here.
Sony TA-F690ES Stereo Integrated Amplifier Manual | HiFi Engine
The photograph shows the left channel power output stage.
There will be multiple component failures resistors, diodes, FETs and Transistors.
The Amplifier is from around 1996 so if your are going to attempt repair verify that the FETs and Transistors are still available.
The repair may prove to be uneconomical.
