sony HST-550W service manual question???
Heres some more info:
The HST-550W is rated with:
25W + 25W continuous RMS power (6 ohms, 1 kHz, 5% THD)
Peak power output: 350W
Total power consumption: 75Watts
Now the STK4131ii (from the datasheet): 20W + 20W (8 Ohms, 20-20kHz, 0.4% THD)
And the STK 4152ii (from the datasheet): 30W + 30W (8 Ohms, 20-20kHz, 0.4% THD)
Also the HST-750W (next model up) is rated at 35W + 35W RMS and it has a STK4141ii (which has 25W +25W from the datasheet)
And the HST-950W (next model) is rated at 50W + 50W RMS (power consumption 130W) and it has a STK4182ii (which is 45W + 45W from the datasheet)
Hope this stuff helps with the answer to the previous post. I really need to know the correct IC as Im replacing the STK IC of the HST550W and the existing IC is missing from the PCB!!!
Solved! :smash:
I have solved my own problem :D Solution for anyone following in the future is below. :worship:
The correct IC for the HST-550w (E model) is STK4152ii.
The correct IC for the HST-550w (AEP/UK model) is STK4131ii.
So it seems there are different ICs for the same sony product in different regions. The E model is rated as 350 peak watts (STK4152ii) and the AEP/UK model is rated as 25w+25w rms (STK4131ii).
Confirmation can be found in the Service manuals:
AEP/UK model is here: Sony HST-550W Service Manual PDF Download
E model is here:
SONY HST-550W E SM Service Manual free download, schematics, eeprom, repair info for electronics
Cheers!
Some more info for the furure reference:
SONY HST 550W
STK4131ii (AEP/UK)
STK4152ii (E)
Output
25W RMS x 2 (AEP/UK)
350W Peak Power (E)
Consumption
80W (AEP)
170W (UK)
75W (E)
Speakers
SS-D550 (E)
SS-A750 (AEP/UK)
SONY HST750W -
STK4141ii (AEP/UK)
STK41??ii (E)
Output
35W RMS x 2 (AEP/UK)
???W Peak Power (E)
Consumption
90W (AEP)
190W (UK)
100W (E)
Speakers
APM-D750 (E)
SS-A750 (AEP/UK)
SONY HST950W
STK4152ii (AEP/UK)
STK4182MK2 (E)
Output
50W RMS x 2 (AEP/UK)
500W Peak Power (E)
Consumption
120W (AEP)
250W (UK)
130W (E)
Speakers
APM-D950 (AEP/UK)
SS-A950 (E)
