Sonic T wall wart
Don't do it! 15V will def fry the t-amp.
I faced the same issue myself. The amp is def fine at 13.8V as long as it's regulated. I read going from 12V to 13.8V increases power output slightly, but don't have the knowledge to say for sure.
I use a big lab-style 13.8V 5A regulated psu, and it makes a huge difference to the body and weight of the sound. Dynamics improve too.
Good luck 🙂
I momentarily use a SMPS power supply - which came together with an USB-harddrive. 12V / 2A , very light and very good sound. I did not even have to modify it or change the plugs. You will very easy get one of those in computer stores.
Here in the UK (and I imagine in most countries) the 13.8V regulated supplies intended for CB radio are plentiful and cheap - often free second-hand! They put out several amps, and seem ideal for the job.
I use one for my SI, and it works very well, just needed a bit of modification to silence the mechanical hum from the transformer.
Picked up a "lightly used" 13.5 vdc, 1.5 amp supply today for 39 cents US. I just love thrift stores!! 😀 Here's a pic of my 39 cent mahogany tray for reboxing. :Pirate:
