Sonance 50wpc stereo power amp modules
Bought a "Higher end" Sonance power amp and the chassis got wrecked in shipping. I am now selling the parts to make up the loss. ( I plan to keep the heatsinks and Toroid)
I have a few of these 50watt (8e) stereo power amplifier modules. All original parts (since all are working pullouts, all tested). They are Very conservatively rated.
At 8 ohms I measured clipping at 26.6vac RMS (That's over 80 watts) and at 4 ohms a little over 25vac RMS (over 150 watts) with its own power supply. To get to these numbers, you will need maximum rails of +/-45vdc. These are absolute max voltages per the uPC1225 predriver IC.
All you need is a transformer and a Bridge rectifier. The kit comes with the Power caps built in. I will explain hook-ups to the buyers once sale is done... very easy.
Uses the very robust Sanken 2sc3519/1860 pair.
Asking for $30 per Stereo module.
1 of 4
I need one two-channel amp module but wouldn't mind getting two to have one for future potential needs, so I will take 2 at $20 each plus shipping. I'm at zip code 48322. If you figure out what shipping cost will be I can remit payment via PayPal. Thanks!
