Someone who would Know Or Rekognize Winding Ratio on these Transformers :-)
And after having thrown that optical TTL Crap Out of my Altibox, and made the output into a proper 75 Ohm SP/DiF Output it Acctually Play's Quite allright to a TV Box be...
But i'm Gonne try lampuzizing it..
To see if the last Bit resolution can be had, (Anyone else in here that have done that, and or Re-Clocked it) Probably Should have Re-Clocked it too with an LC-Clock or similair, if one where to expect the Full potensial tho... 🙂 But if memory serves
(and that sure as hell aint what it was since i turned 50 on wednesday) It Had a rather High frequency Clock to the ONE & Only Chip inside..... 🙂
If you like fireworks just connect supply caps with polarity inverted and replace mains fuse with rolled up aluminum paper.
Then stand back and flip power switch ON 🙂
well did that to some 40 years Back,, Got boring pretty quick and det cord muuuch more fun... 😎
But just as i wrote this rememberd a Beast of a capacitor, From an X-Ray Machine,, at least i think it was from that,, since back then they scrapped the hospital in Stavanger and an uncle of mine pretty Much Cleaned the Place Out Of ALL HV Electronic Components.... 🙂
Mmmh i think after some Brain Digging i remember the specs on it (it was almost half as large or small as i was at that age)
Nonetheless i'm pretty sure the capacitance was o,15 Microfarad @ some 1oo or 150 Kilo Volts...... 😎 Although Not quite as sure on the voltage number as i am on the capacitance number...
Nonetheless i was bearly a teenager and used some pulsed L arrangement to chrge it uP 🙂 🙂 And that i can asure you made quite the bang, when shorted.... 🙂
And Why would i wanna do a thing like that.?? If i May ask.??
It Probably had if not internally shorted the EL-Caps, Burnt them Off,
And Or Wasted Precious Resources, But Let Us NoT Even Touch That Politicly Hot Potato Especially.!! in this case,
And in the very least made them Crappy'er then they already Are....
And foremost
If i Craved & Sought Fireworks that Much.!!
It Probably
Would be all less Resource Wasteful, TimeConsuming And Easy'er To Whoop uP Some, TnT, AcetoneTetraPeroxide, HexaMethyleneTetraAmine, Or For the layman in chemistry,, RDX, C4, Plastic, Or Whatever One wanna call it .......... 🙂
If you have not OverStrained Your eyes, or whatever yet, you can probably From my description of some of the chemicals above surmise where my character swapping comes From...
Remember
i Have Had to learn most of my skillset's all by myself, and therefor that kind of forced me to do it MY WAY, or rather whatever way worked for me...... 🙂 😎 🙂
Oh, definitely 😉
stock-photo-fire-fireworks-celebrate-kids-sparklers-new-years-fourth-of-july-63a367aa-67c4-4bcb-8c8b-058ae5689d36.jpg
ChaRacTer swaPinG isn’t going to get you off any terrorist watch list. They can watch all they want - even if i’m turning old electrolytic caps into confetti. Was it CDE that used to mark their CG soup cans with “Misapplication Hazardous”? Consider that a challenge, not a warning. Back when I was growing up in Florida - all fireworks except sparklers were illegal and I didn’t have the means to drive to Georgia to get them so I resorted to electrolytic caps since I was old enough to unsolder them from junked equipment.
I can make far more noise with SPEAKERS today. Ever heard that super high fidelity recoding of a fireworks show through a full stack of lab horns (and tops that will keep up)? It brings the cops faster than actual ****-ant class C fireworks do. And it does NOT violate the burn ban when one is in effect due to dry weather or result in a $2000 fine for violating city ordinance. The most they can do is tell you to turn it off.
What would be far more suspicious if anyone bothered to look in on it would be all the transformer winding equipment.
