Hello, i have some of these GK71 Russian tubes and i want make SE amp with two (i think) of them..
Someone please help with shematic for these tubes?
Thank You in advice
Best Reggards!
Thank You in advice
Best Reggards!
eh
Hello Tube Manicas, is there anyone who may help me with ideas about GK71 in some sheme for amplifier?!
This is the same tube as a GM70. here are 2 links.
http://diyparadise.com/nikcgm70.html
http://www.republika.pl/diytriode/drugi_eng.htm
Thank You for Your reply...
In the beginning when I wanted to make some SE "monster" I go gor GM70 choice, but there is so difficult getting two of GM70, and then i go to second choice - GK71, that's because i already have these tubes. But I don't think that GK71 is analog to GM70... even in triode use... 🙁
The polish link I know from before, but the other is new to me, but thank You for the links ...
The question is remain the same- the sheme with GK71 in SE
maybe with 6c33c or gu50 - driver... I don't know yet...
any suggestions are necessary and welcome!
hm, i don't want ecl... but Thank You
I think about something like: GK71 in triode - mode, plus Triode for driver, i thing about double triode 6SN7 ot probably Russian analog 6H8C. Without transformer between two lamps, but only output transformer. Power about 800-900V... Something like this
Best Reggards!
Niki / Bulgaria
Best Reggards!
Niki / Bulgaria
6H7C + Gm-70
I bought 17 ea. GM-70 tubes for my projects in Russia and planning to make se amp using 6H7C triode tube as driver. I was talked by Russian old guys that, this driver tube will give me good result with GM-70. I want to use 800-900v DC. I will use silicone diode rectifiers. Do you have any shematic for this?
hm... i have to think about this...
I think that 6n8s is better than 6n7s in this case because i may use only one tube for two gk71... and i've heard from some diyers that 6n8s is more musical tube than 6n7s
In the other case look at attachment for interesting sheme with GM70 from A.Manakova - one of the best RU diyers 🙂
Best Reggards
p.s. and what about output transformers?
i've heard for something Turkish firm that make this kind of transformers?
Best Reggards
How much gain do you want?
I wasn't able to find the datasheet of the GK71. But anyhow, if is similar to the GM70, you could probably use the 417A or the 6C45PE as a single driver tube.
That way, you could keep a two stage topology and as both driver tubes will give a relatively low output impedance stage, you probably won't need an interstage trans.
Rada
Rada
If you need any info for Russian components I can help you.
Try to email bobkey at mail in ru.
73! de Bob RZ6AT Krasnodar, Russia.
hi, I'm italian, the gm70 and gk71 have the same sound? you have see one gk71 at work?
ps I'm iterested at the gm70... please contact me in private, thanks andrea
Hello.
I projected some small amp 😉 Look on this picture and say what do you think about it.
I going to make in this year🙂 .
Other version of this project:
V1,V2 without changes. I would like cut V3 because it is unnecessary when V4 (GK71) working in A2. I don't like A2
Only A1.
Kacper
PS. Sorry but my English language is not very good
Kacper
Last one...
I try third time... Last one...
http://www.fotosik.pl/pokaz_obrazek/pelny/0591bb693b779917.html
Bob Key said:If you need any info for Russian components I can help you.
Bob Key; do you know by a chance Sergey Kiryasov? If I remember right he lives in Krasnodar as well...
- Tubes / Valves
- Someone help: SE shematic with GK71?
