• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Some tubes for sale,
I have a few tubes to sell. I'm trying to save up some money for some decent OPT's witch are out of my budget at the moment
PCL86 Philips/valvo used tubes €3 each tested above 80% Good alternative for the ECL86. you can use a voltage doubler to run these instead of those overpriced tubes.
PCL82 Philips Siemens Valvo €2 each tested above 80%
About 48 ECC2000 tubes Gold pins can't test these/ Offer for the lot.
PY500A Philips, nice damper diodes €2.50 each tested for forwards voltage drop.
PCF80 Philips. Triode pentode used untested €0,25 each
Philips ECC82/12AU7 tested above 80% €10 each. The label might be slightly faded. yet the seams at the top and factory code identify these as tubes made by the Philips conglomerate
Philips ECC83/12AX7 tested above 80% €15 each. The label might be slightly faded or completely wiped. completely wiped tubes are less.
PY88 dampers €0,50 each. I won't bother testing these for this price .
PL519 Used €15 each tested above 70%
I will test/match for bias current as per the datasheet. Matched pairs on request.
Shippig worldwide is no problem, Payment by Bank transfer or Paypal.
Please feel free to ask any questions you might have,
Photo´s on request.
V4lve.
