Some questions about class D amp design
Okay, so I'm starting to work again on this project after a long hiatus. It's a class D full bridge amp intended to be used for subwoofers so it doesn't need to be exactly hifi, and it uses HIP4081 and discretes. Anyways, I still have a couple of questions about design:
1. How should grounding be done? Currently I have separate ground for the high-current signal, and for driver chip and PWM modulator.
2. Should I use some fast recovery diodes parallel to the body diodes in FETs?
Here's the schematic and layout:
http://koti.mbnet.fi/~jokunen_/classD_schematic.png
http://koti.mbnet.fi/~jokunen_/classD_layout.png
