Some pics of my modded Rotel RCD-991
Just wanted to share...over 50 electrolytic caps were replaced, including 18 of the 22 Blackgates F that came stock with the player. Opamps were also upgraded from OPA2604s and NE5532s to OPA627BPs. Replacement caps include Elna Cerafines(4), Elna RJHs(8), Sanyo Oscons(14) and Panasonic FCs(27, I think). There are only 6 stock electrolytic caps left on the player.
Hi guys. There was a small but very noticable improvement in bass,dynamics, speed, transparency and soundstage, but without becoming more harsh or sibilant. Those who prefer a warmer and more laid back presentation may not like the changes brought about by the mods. I'm thinking the blackgates somehow gave a slight veil to the presentation. None of the blackgates removed were directly in the signal path, all were supplying power and we opted to replace them with ultra low-impedance caps, in the case of the caps supplying power to the DAC chips sanyo oscons were used. I forgot to mention that the opa627 opamps were biased into class A as well (the class a modules are not visible because they are mounted underneath the pcb)
All mods done by a friend, in stages, we spent lots of time talking and poring over datasheets.
RCD 991 Mods
How did approach biasing the 627's into Class A.
I have a 971 that I replaced the 2604's with 627B as well.
I did add 6-7 OSCONs as well as 8 or so Pany FC as well changing all 9 PS diodes to Schottkys as well as adding .068uF between pin + & - pins of the OPA627's.
Let me know.
Thanks,
Dan
That's slightly odd - if you wanted a less 'laid back' sound, why did you put in OP627s?
I would recommend that you try the OPA2107 if you want something with the bass of the OPA627 with a little more energy. Other alternatives could be the AD8620 (on adaptor), AD746, AD823 or AD712.
I have a friend's 991 and am planning to better the analog sound by opamp rolling. 627 is certainly the most fav opamp as I love the sound off them. Apart from the OPA 2604 that the Rotel 991 uses (1 per ch), there are 2 more NE5534 in there AFTER the I/V. Are they also to go in fav of 627?
Attached a schematic.
Suggestions and recommendations will be most appreciated.
Thanks in advance! 🙂
For anyone blindly swapping 🙂
Just in case any one thinks of blindly swapping an NE5532 or OPA2604 for an OPA627 (yes I see you used adapters) then your going to be in for a shock... the OPA is a single device, the other are duals.
It's interesting reading listening impressions on opamps in CD players. Must admit I do like the OPA604/2604 particularly as an IV convertor on a TDA1305 DAC. Far more musical than the NE5534.
@ Mooly :
Yes, am aware the 627s are single hence for 2604 will require a browndog adapter with 2 x 627s mounted for every 2604.
But in the positions where the 5534 are which are single OPAs, was just wondering if it would be beneficial going the 627 there. Inputs will be welcomed.
Cheers!!
It's very subjective, and will depend on each implementation too. I'll be honest, I've never tried or used the 627 at all.
I do know I preferred the OPA604 to the NE5534 as a V/I convertor as I mentioned above, and I also use an AD845 as an output buffer/filter. That's in a Micromega Stage 2.
Your just going to have to try it I think.
Thanks...
One final thought. Might be worth adding a few tens of ohms at the output if it's used to drive interconnects directly.
It's something I did with the AD845 as a precaution to isolate the opamp from capacitive effects.
