Some ICs sitting around, what should I build?
Hi, I guess you have to search online but I'm not confident you will find
one that uses all the ICs you have in one circuit.If you follow the data sheets
or other similar circuits available you should be able to draw up a circuit
and send it to a pcb maker for a prototype pcb.(Although I'm not supposed
to say this, use a cracked version of eagle professional and get around the
limitation of 3 X 4 inch pcb.It's easily found in file library sites.Note there
are many versions.Pick one that says cracked with the patch file included.)😉
Ok, ezDAC still has a few boards, so that is an option. The only other board out there I can find is the Twisted Pear COD. Anyone have an opinion on which sounds better?
Shoot, I wish I had a PCM 2706 rather than a 2704, I could have done a Mute Audio Grub DAC.
