Hi to every body.
I was looking for some information about crossover distortion and found this site with a good tutorial that I decided to share it with the Diyaudio members. The tutorial is good for newbies since it is explained the appliers design with drawings and examples. Enjoy it.
Here is the link Introduction to the Amplifier Tutorial
Regards,
tauro0221
Regards,
tauro0221
That article contains a few mistakes and minor confusions, so be careful. OK as a place to start from, but don't take it as absolute truth.
Examples:
it confuses 'perfect' with 'ideal'
it says Class B has "maximum theoretical efficiency of about 70%"; the correct figure is about 78% (actually pi/4).
Examples:
That is a common problem for instructors who try to present fundamental concepts, without cluttering the explanation with subtleties, details, exceptions, etc.That article contains a few mistakes and minor confusions, so be careful. OK as a place to start from, but don't take it as absolute truth.
Another example:
". . . Gain is a ratio, it has no units but is given the symbol "A" . . . "
Often true, especially when considering "gain" in a strictly mathematical sense. But even if you ignore the common use of decibel notation, engineers often scale gain values to, for example, "V/mV" or "V/uV". And then there are the cases where it's more informative to use concepts such as transconductance gain, with units of Siemens (or mhos) and symbolized as "gm".
And we haven't even begun to touch on the fact that "gain" has both magnitude and phase angle; and the "gain" value of practical circuits typically varies with frequency as well as signal level, etc, etc . . .
See what I mean about the challenges to an author who wants to present a basic concept?
Nevertheless . . . that web page is well organized and quite informative!
Dale
