Solid State Rectifier in Dynaco Tube Amp
replacing the tube rectifier 5ar4 simply means a savings of around 12 watts of power, power that is now available for the output tubes, and that is just 3 watts a piece, not too much i think...
if the el34's were running 14 watts per plate, that is an increase to 17 watts, not too much either....
First: using SS rectifier will increase power dissipate over output tubes; means shorter life of output tubes.
You can use different power transformer or use tube rectifier. Or use a variac to reduce ac input voltage.
Or, just reduce the size of the first B+ capacitor. Lower peak currents, no heater consumption, adjustable for modern AC power line voltages. Fairly painless.
All good fortune,
Chris
Many many years ago I replaced a failed PA60 power transformer in a 1970's vintage Dynaco ST70 with a reissue power transformer from Triode Electronics of Chicago. This was in the mid 1990's if I remember correctly.
At that time the Triode Electronics PA60 replacement was specially made to provide the original factory B+ voltage with solid state diodes. It did NOT have a 5V filament winding for a rectifier tube. It was also taller and heavier than the original power transformer and it still works perfectly, 25 years later. It barely gets warm.
I just dug this ST70 amp out of storage and I will run some measurements on it and post the B+ voltage and output tube bias voltages/currents here after I check it out.
Triode Electronics is still around, and they still specialize in high-quality replacement transformers for Dynaco and for almost every tube/valve guitar amplifier in existence:
POWER TRANSFORMERS - MADE IN USA
However, the current production Triode Electronics replacement PA60 for the ST70 is more like a heavy-duty version of the original Dynaco PA-060, with the 5V filament winding for the GZ34/5AR4 rectifier. So it might generate excessive B+ voltage when used with diodes rather than a valve rectifier:
PA060 S Dynaco ST70 Upgrade Power Transformer Replacement MADE IN USA
There are plenty of designs and drop-in products to replace tube/valve rectifier tubes with diodes. Some of them are just 2 diodes inside a plastic tube base. Others include a series resistor.
I've had some thoughts about measuring a bunch of actual GZ34/5AR4 tubes under load and then designing a solid-state replacement that has the same voltage drop and voltage vs. current characteristics as an original GZ34/5AR4.
I think it would be challenging to duplicate the original "slow turn on" characteristic of an actual tube/valve rectifier. However, I haven't observed a higher failure rate of EL34 otuput tubes during 25+ years of using my ST70 with a solid-stage rectifier. So perhaps the slow turn-on isn't needed for EL34 output tubes?
-EB
