People here is one simple question how to solder two aliuminium bars together?But it must be under 400°C.Maybe some chemics can work?
yeah. aluminium is an excellent "de-oxidant" and if exposed to oxygen / air, it will burn fiercely.
aluminum powder is actually used in some bombs (fuel air explosives, like the ones dropped in Iraq).
so unless you can control that (like in vaccum), it is unlikely you will be able to solder / welder alumium parts.
You can fusion weld aluminum at sub 400C.
You need to get yourself a torch and a tecnoweld kit.
Where are you from??
Magura
Magura
I appreciate the geographical lesson 🙂
...But i have been living in Latvia for about 3 years.....went back to denmark 4 years ago.
In that case its very easy. If you look at the internet, the technoweld webpage has a number of representatives. One of them is situated in Ogre close to Riga. Its a one man band type of company, he is very nice and easy to deal with. Im sure you can buy a technoweld set from him. Its something like 6 or 7 Lats.
If you cant find him, just ask again....ill ask the guy i buy it from, where the Latvian representative have ended up.
Cheers
Magura
Cheers
Magura
rulezzz said:can u write the chemic formula how aluminim burn cos i can get pure oxygen!😎
You dont wanna try that at home....it dosnt burn....it is more like an explosive at the right temperature.
Just ask anyone from the british navy.....an aluminium battleship blew up during the falkland war 🙁
Magura
I just checked the Elfa catalogue and there is a Multicore solder
called Alusol that is claimed to work for soldering aluminium at
350 deg. C. I have never tried it myself, so I know nothing more
about it, or whether it is any better/worse than what Magura
suggested.
Elfa claim you can buy from them through local retailes in the
Baltic countries, so if this is interesting, I suggest you email
them and ask where to buy in Latvia.
www.elfa.se click the english flag (or polish or whatever
language you prefer) then search for "alusol".
suggested.
I have built a few yagi antennas of aluminium by soldering the elements to the boom. There is a solder for this purpose. I found one link in a quick search:
Loctite Hungary
It can be hard soldered too, did that many years ago in school.
Loctite Hungary
I know aluminium solder exists and what it can do....soldering two bars together isnt one of them 🙂
With the technoweld solution its possible to do over a gas stove....as im sure he has in Lithuania 🙂
Magura
Magura
- soldering
