I need to connect very low gauge Cardas wire (I'd guess 10-12ga.), to the tiny posts of a Seas tweeter. Previously the connection was soldered but it looks like a bear to redo as there's not much extra length on the wire connected to the crossover, which makes connecting the two more difficult.
Any recommendations to solder thi succesfully? Should I try to find crimp ons and go that route? Thanks!
Maybe a hot air gun or plumbing torch.
With no success with a 350 watt soldering iron (on 32 mil sheet copper), I used silver impregnated epoxy (Tra-Duct 2924 Conductive Silver Epoxy Adhesive) for the following . . .
I've seen a silver-based solderless epoxy at Radio Shack.
Keep in mind, the electrical properties, namely low resistance, of conductive epoxy are not as good a solder.
Thanks for the replies. I found crimp on quick connects at RShack that will accomodate 10-12ga wire. How about using these with a little Stabilant 22 and heat shrink? I've read that some prefer crimped connectors over soldering including George Cardas. What's your take on crimped connectors?
Well...crimping is not as good as soldering of course. Will it work...yes it will. As far as which is better, depends on what you are doing. In your case it wold be sufficient for a quick fix. If you were using a much smaller diameter wire, then the advantage is to solder the connection. The fear of using solder is that it is not the best conducting medium between the conductor and surface to be connected. BUT, making sure you have a direct contact with the surface FIRST, then soldering alleviates any worries. Make sure you make a sufficient crimp so as to not induce mechanical instability to the connection (moving around and such.)
- Soldering Tips
