Soldering tips for odd chassis-mount RCA
I got a set of chassis-mount RCA connectors, and they have a slightly odd case design (see attached). I'm wondering what the best way to make a good solder connection would be. Wrap the ground wire around the whole thing to anchor it? Tack-solder? Wrap it between those two notches?
  • HiFi-conector-hembra-RCA-grueso-de-Cardas-GRFA-conector-de-montaje-en-Panel-de-chasis-adaptado...jpg
I would use them with a grounded chassis AKA chassis and jack body are common... If that's not possible and you don't want to buy a tag like rayma suggested, I would wrap the ground around the jack, loop the end through, and pull it tight like a slipknot. Then get some solder on it but if you use 18 solid you can probably just wire wrap it. If soldering, get it hot and perhaps give it a bit of a key with some 600 grit paper or something to make it less "shiny"...
Here's another option that should be was less money that anything Keystone makes 🙂
https://nz.rs-online.com/web/p/ring-terminals/6881237
