Solder Station. Opinions please
where you guys buy GOOD quality pot of tinning paste? Can you recommend US suppliers? (btw, still using tin/led solder and no plans to go led free).
I thought that by getting PLATO TT-95 (Made in USA) Tip-Tin, it chemistry will help any buildup carbon deposits on the tip to be removed too other than a simple tinning.
Well in my case it does not work that good, no matter the Tip temperature selection.
I use a fiberglass brush to remove stubborn deposits from time to time and wet cellulose sponge always. Wire brushes just don't get it for me
If you use a silver alloy solder it would be wise to keep the tip used seperate from the rest. Silver oxidizes very quickly and it will never come off. This will lead to a shorter tip life if left on for any extended length of time. Watch the color change as it oxidizes, will give indication of when it needs help. Retinning with regular leaded solder helps rewet the tips, but it doesn't last long. Retin very often. I always redress the silvered tip just prior to shutdown.
BTW a Hakko 470 station that retailed for $450 only cost $250 wholesale. Mention this just to put markup into perspective. 🙂
Water based organic RMA type fluxes work very well. I have various types collected over the years. Normally use an RA paster type from Kester. Still have spools of the good old leaded solder, Kester44 and Ersin multicore are favorites.
Love my Hakko 880 I only use it for new jobs, then again I have been using a $13 radio shack 30 watt iron for decades, when they quit working I go buy another. Soldered in chips on the C=64 and 128's tro modern day chip amps.
The Hakko is a dream compared to normal soldering irons.
Wrong consept.
But even so, when you are limited to a very low budget, you have only one alternative which is to not buy anything.
The person who feels really sad is a qualifying professional with a poor tool at hand, currently there is only four soldering stations ( four models from several brands) that qualify enough as worth having them and Hakko is not one of them.
It would be more sincere your topic to include your budget limit up front.
I am repairing this minute, an APC RS-1500 UPS, my happiness is that I am desoldering and measuring from tiny surface mount capacitors up to high voltage electrolytic by using the same tip and soldering station, and the most important .. with out destroying the PCB.
I am working for two hours with it, and if my repair gets successful by doing simply re-cap of the bad ones, I would gain 80$ USD, which is the food on my table.
Therefore if your soldering station acts the same in your hands? Only then you can feel happy for it.
PCB damage due a worthless soldering station is not an option for me, I need to protect the property of my customer and my own reputation.
