Solder issues
Joined 2002
A friend was trying to solder on a new capacitor on a car amp. The solder he is using will not melt or stick to the solder on the board. He has scraped the surface of the solder on the board. I'm assuming the solder on the board has a higher melting point. He is using the usual Lead based solder.
Are all RoHS compatible solder harder to melt ? Would anyone be using solder with silver content on consumer products ?
Any solution to this ?
Thanks.
RoHS compliant solder is Silver bearing and it does melt at a higher point.
Some of the silver bearing solders need over 700deg. to melt properly.
A good quality 63/37 eutectic solder will melt much lower but you won't hurt it by overheating, just keep steady while it cools and you will be fine.
You will probably need to use some acetone (nail polish remover) to clean the area really good and then use de-soldering braid to remove the bulk of the old stuff.
I do this all the time at work and it shouldn't fight you at all.
I was my understanding that at typical tip temps (based on PACE PCB repair station training) that after 3 seconds of melt time the Tin & Lead in the alloy can seperate, leaving an overheated joint that is unacceptable, hard as nails, and generally a mess. I've not heard of any solder alloys that are not overheatable.
A lot of soldering problems stem from the use of too-small elements/tips that cannot give quick enough heat capacity and transfer. PACE recommends the larger sizes, and 3 sec. max heat application once the melt occurs. I use 50W minimum element with 3/16" chisel tips. They are 1950's - 1960's NOS Western Electric tips that fit in a cheap (~$18) Weller Iron. The tip I am currently using has been in service for about 4 years and remains perfect. The Weller tips go out in about 6 Mo. and cost more than the iron kit itself!
I was very fortunate to have received the PACE training in the U.S. Navy, and following those methods actually makes soldering pretty easy.
I also lucked out and found some expired shelf-life Kester liquid flux that is the cat's pajamas. Diluted slightly with 99% Isopropyl alcohol, it's as good as it gets (used to get?). It's probably considered super deadly these days.
How many tree huggers do you know of who solder, anyway?
($.02 worth) of MHO
Also the greatest thing I've seen lately are the little foam-core sanding blocks (~3" x 4" x 1") in various grits; nothing cleans a component lead like these darlings.
I can usually find 3M pads at a 99 cent store locally. They are around $5 - $6 at Home Depot.
3M 2-5/8 in. x 3-3/4 in. Medium Sanding Sponges (6-Pack)-CP002-6P-CC at The Home Depot
You can cut them into small pieces and hold one with a hemostat to get into tight places.
I would highly recommend trying these out, you'll be amazed.
Heck, they even work great for the sanding tasks they're intended for!
RE: Mixing silver and tin-lead solders
When it was the norm to have almost all joints in a Tektronix scope silver- bearing soldered, unknowing repairers would use standard SnPb solder instead.
the result was a nearly 100% probability of connection failure short-term. Then often the situation would see a "snowball effect" and everything went from bad to much worse.
Admitedly I <once> made the mistake, turning a $50 work surplus Tek 530 into a $195 repair (including a few tubes) and and yet another unscheduled project.
Another lesson learned the hard & $$ way.
I still have a handful of the ceramic, silver bearing solder
terminal strips from NOS Tek repair kits. But THEY can be a handful to solder. Very pretty to look at, though.
Quote: "If you use solder with 1% copper, that extends the life of the Weller tips."
Thanks for the tip tip.
Who is a reasonable priced vendor for the 1% Cu solder? (USA)
I've also had to do repairs on the Weller's (oops, this one's a 40W! Model SP40L) power cord several times, but since ditching their tips it' been a real trooper. One nice feature is a neon lamp inside to indicate power-on.
Ha ha, it's marked "Use Weller replacement tips only".
Forgot to mention also, I use a 100W "Variac" with it to reduce temp. to where the tip does not discolor when tinned (overheated solder). I can "floor" it when needed for heavy joints.
A mechanical "twist timer" AC switch is a good feature for homebrew solder stations. I've ruined and shortened the life span on too many irons to trust such things to real-time cognizance.
Not that I know of.....I REALLY like the Cardas Quad, I have not tried the Cardas Tri-Eutectic without lead and I may try that some day.
It may just be the special flux core that makes it work so well.
I would say Kester 44 63/37 is a close second for useability but the Cardas Quad makes much nicer looking joints and it melts @ 338F just as the specs say.
I have a Pace Process Control Station and I verified the temperature.
Thanks.
if it doesn't melt, how can it 'stick' to anything
it is difficult to melt existing/old soldering without any melted solder on your tip
I have experienced this once, with a completely burned out tip
and that may happen if you forget your iron with power on 😱
with some luck you may be able to 'relive' your tip by rubbing in repeatedly on copper wire, with solder
keep doing it until the solder begins to stick to the tip
or your iron heating element may be gone
