sola cvs
i picked up a sola cvs today,
i really dont know whet applications it can be used for, are there any pertaining to audio testing or use?
It's a voltage regulator with high source impedance. Would work well feeding a preamp, but should be undersized if you want to run a power amp, maybe 30%.
I use one with excellent results feeding all my heaters and filaments; ultra quiet supply, regulated, and likes resistive loads. Rectification is run off unregulated ac line.
