What is the maximum VA Toroid that your soft start can handle without modifications? I have a 1600 VA (actually a 2400 va wired to provide only 1600 VA ).
Thanks!
Thanks!
If you added primary turns for the given voltage then you may have seriously reduced the startup surge current. If you are using less secondary then there will be no change from the typical 2400VA transformer.
http://www.connexelectronic.com/documents/Power_SoftStart.pdf
Maximum current is limited to 24A RMS. A 1600VA at 110V mains can be used with PSS.
