Planing to put a choke just after the 15V tranny to filter some noise. Any comments on this....will it works...? 😕
zei said:You have noise from the transformer?
/JZ
don't know...just want too add extra filtering stage......
any comments?
if there's a bulk i'll definitely buy from them....
any comments?
If it aint broken, Don,nt fix it... 😉
I would not put it there unless there was a good reason for it. If you understand.
/JZ
Zei, i am sorry to tell you that i cannot download the all the files posted in POST#1. will you please check them? thx.
µÂÂÉ·ç¸ú said:Zei, i am sorry to tell you that i cannot download the all the files posted in POST#1. will you please check them? thx.
are you planing to build the pcb?
The server where the files are located are not active for the moment.
If someone has some hosting space i be glad to mail the files to you..
/JZ
/JZ
You can use this or some another service:
http://smages.com/
Just upload photo and then post here link from first string...
It will take a couple of minutes to download photos 🙂
http://smages.com/
My friend Per-Anders is kind to host the files for some time.
Heres the link.
SOAP Files...
Thanx P-A !!
/JZ
Heres the link.
SOAP Files...
Thanx P-A !!
/JZ
Hi.
Zei, can You share layout cad file, or make please one more version for soic opamp.
Thanks.
Thanks.
Hello again 😀
I have 10VA transformer with two +12V rails, can I use it with SOAp? I mean that It will be stabilized to 10-10.5V with LM317 so supply voltage will be +-10.5V but not +-15 as in reference sheme...
I run mine at about 10v per rail as I feel it sounds better like that. The regs will run a little hotter, but don't need heatsinks.
will, i wanna have a look at the files to judge if it worth building....gabanyayaya said:
hello.
i think it will work with the ne5532......it is a standard application.
greetings............
is the 5532 decoupled as per specification.
The 32 is already unity gain stable. Do you have a scope to look at what a squarewave does as it passes from input to output?
For me...improving the quality of the in/output caps gave the most noticeable improvement.
http://www.diyaudio.com/forums/showthread.php?postid=1672816#post1672816
- Chip Amps
- SOAP MKIII (Simple OpAmp Pre) With onboard PSU
