SOAP EVOLUTION - Simple OpAmp Pre
This aint no revolution, however it is the SOAP Evolution .. :)
After some time of silence i now have tuned the SOAP preamp to a more complete version.
There was some request to have it even more simpel then the MKIII but i decided that it already was very simple (and cheap).
This version contains a full onboard PSU. Onboard trafo, Dual discrete rectifier, room for more smooting caps.
The in/out caps has switched placed for placement reason. (Out caps are generelly bigger)
Grounding has been optimized even further. :cool:
This version will make installation a piece of cake with less cabling. :)
Testing will follow shortly.
A first glance on how it looks.. :D
/JZ
Hi AndrewT
Thanx for the tip and heads up..
Proberly not without going 2layer..
Even if it looks like a 2 layer design i only made the groundtrace red to be able to "see" it easier. It is made with one copper layer so that anyone can make there own. Keep it simple ;)
However, Even without AndrewT,s nanooptimized grounding.. It has a pitchblack deadsilent background.. No groundnoise, hum or whatever.. :cool:
If anyone want to give it a try, PM me for a PDF of the layers..
I maaaaybe maybe will have a bunch of these promade.. maybe.
/JZ
Neurochrome.com
Joined 2009
I would route the ground for the 100k R12, R13 separately and not share it with the decoupling ground for the op-amp. You should be able to weave it through on the bottom (blue) layer. Same for R1, R6.
If you stay with the board as-is, I suggest dropping the top (red) traces to the bottom (blue) layer and having the board made with only one layer. I don't see any reason to go through the expense of a 2-layer board unless you have to. I think even with my mods above, you might be able to make it with one layer.
~Tom
Hi Tom.
Thanx for the ground routing tip. i,ll see if i think it is worth it :)
And excuse my english, Maybe i explain to poor but in the Answer to AndrewT,s post i stated that this is in fact a one layer design.
I have only the groundlayer i "red" (top layer)so that it is easier to see :)
If/when sent to a PCB factory i,ll change so that all is on the same layer. ;)
/JZ
