So Sick of SEARCHING, help me find a good +/- 24v regulator PLEASE!
Yes, this is possible.
To make 2 LM317 circuits. Identical.
And then you stack them one on top of each other.
One for the positive half
and one for the negative half.
One hook only:
You have to use Transformer with 2 Separate windings!
( one with a common middlepoint for Ground, will not work )
So make sure you buy 2 x 12 Volt trafo. Or what voltage you will use.
