Snubber board for IXYS SOT-227B diodes
Hi All,
I have built a couple of amps in the past using either the GPBC block type diodes or the PSU V3 diodes from the store.
I wanted something "fancier" than the block rectifier without going through the hassle (and cost of needed parts) to assemble the diode boards from the store.
So I cobbled together a small prototype board as attached mainly to confirm the footprint etc.
The SOT-227B should fit the perforated base plate of the shop chassis.
I have attached some pics that should be pretty self explanatory.
The boards are 26x39mm , 1,6mm thick and 1oz copper only on the test run and admittedly the resistor positionning is somewhat dodgy, I got lost in the 0,01mm grid in Kicad...
In someone is interested in a couple of boards for a built and willing to give me some feedback I'd happily send a couple of those out.
If this raises enough interest I could offer a group buy (of slighly modified boards in 2mm and 2oz) incl. the IXYS diodes for around 50% of the price at the major distributors (fellow DIYer has lifetime stash of those for whatever reason).
Looking forward to you thoughts.
EDIT: Pictures comming in 2nd post, forgot to crop them...
  • VBO40-08NO6-1549538.pdf
