SMSL M300 MKII What do the PCM, DSD, Sound Color Modes Do?
Hi guys, I have the SMSL connected via bluetooth. Then into a topping TP60 Amp. Sounds great.
What do the following modes mean? Does the PCM filter 1-6 even apply when connected via Bluetooth?
PCM FL1-6
DSD Filter Narrow / Wide
Sound Color 1-3
HighSound Enable / Disable ( I belive this is a highpass filter? but no sub out on amp so not sure )
If anyone has a thread or chart to reference to this would be great. What do these modes mean?
Thanks for the help
PS Why do you have to press C on remote before even operating the SMSL device?! Took me like 30 mins and 2x battery changes on remote to find this out.
M300 MKⅡ
Bluetooth Audio DAC
New series ID design, with glass panel, stylish and long life.
AKM's flagship audio DAC AK4497, Ultra-high SNR, ultra-low distortion, support DSD.
The 2nd XMOS solution, PCM supports up to 32bit/768kHz, and DSD supports up to DSD512, custom driver for Native DSD .
Two ultra-low phase noise crystal for 44.1/48kHz multiple frequencies.
Built-in high-efficiency power module and lots of low-noise LDOs provide pure power for analog circuit .
Lots of audio grade components, include MELF resistors, NP0 capacitor, Gold-plated jacks.
Use a 1.54-inch high-resolution full-view color IPS display, and the user can choose the color of fonts.
True balanced output and high-quality XLR connector.
6 digital filters for different music listening.
Full aluminum CNC milling chassis.
  • M300MK2Manual.pdf
    M300MK2Manual.pdf
  • two pages.pdf
    two pages.pdf
Hello,
I also bought this DAC .... I made several changes of Audio Filters .... but my "ears" didn't hear any differences between them ... I don't understand. Maybe if someone more experienced who owns this item ....
In mine I found that the optical input does not go beyond 96kHz / 24 bit .... while the coaxial input goes has 192kHz / 24 bit ..... does yours also work like this?
