Hello
Regarding: SMPS600RS from Connex.
For the ease of use, I wonder if I can use this SMPS for Zen v9 or F3 clone? It’s a single supply and adjustable to 46 volt. As an inexperienced DIY’er, this SMPS solution would help me a lot if it’s an acceptable way to go.
Next question: If so, do I have to use one SMPS600RS pr. channel?
Here is the specifications for SMPS:
http://connexelectronic.com/wp-content/uploads/2017/09/SMPS600RS.pdf
Baard
Baard
Looks like:
1. it will work OK
2. one SMPS should be sufficient for both channels.
3. if it's cheap enough use one per channel for better separation (consider mono blocks)
1. it will work OK
My Aleph J runs off two SMPS supplies (one for each rail). Works well and sounds good!
I used CLC filters to block the residual high-frequency switching noise. I don't think it makes a huge difference to the sound, but I can sleep better.
Zen V9 and F3 already include Cap Mx , check the circuit diagrams.
That means high freq. switching noise is reduced to practically non-existant.
Plus an additional soft start feature.
CLC or CRC filters will not work with every SMPS, some will become unstable and shut down.
Now RCRC might be a better proposition.
The CapMx as in Zen V9 / F3 is a better option IMHO.
