Are they good for passive crossovers if chose with enough Vdc voltage >100 Vdc ? Or is too much current for such smd caps ?... Always wanted to try those in passive filters while I do not want to destroy a driver !
There are smd PPS caps in several uF now for illustration.
I think poly caps are much thicker, those look like ceramic caps.The caps are on the board, and the resistors are inside that xo module. Can you tell what type of caps those are from the picture?
