Hi El_d,
It's a standard (ie. non-special) electrolytic capacitor.
It's value can be read as 22microFarad (of capacitance), 35Volts (max. voltage).
I don't know about local shops/suppliers in your area, but as it is a fairly standard type, every reasonable electronics guys should be able to sell you one (i.e. an expensive one would be Elfa).
Another good question would be why it failed! 😎
Looks like you accidentally ripped it off... 😉
Sebastian.
El_d said:I'm looking for an SMD capacitor that is broken on an ICE-power module.
Please tell me what brand it is and where I can get it.
Sebastian.
Thanks a lot sek.
So you think I should use a standard cap, and not a low impedance cap..?
About the question why it failed...
I think it must have happened during the shipping, It was like this when I received it.
/Daniel
/Daniel
Those ICE modules are pretty heavy due to the aluminium and SMD parts are fragile. A normal private person will probably underestimate what the modules will be put through during shipping. => careful packaging and much of chock absorbing stuff.
Hi Daniel, 😀
The one that broke off is a standard type, so no low ESR type is required.
I don't know what it's supposed to do in the circuit (I don't know the schematic), so I can't say what a low ESR type would do here. 😉
Sebastian.
Sebastian.
Hi sek.
Thanks again.
/Daniel
Then I will go for the standard type.The one that broke off is a standard type, so no low ESR type is required.
Thanks again.
/Daniel
It would seem to me that if you purchased it from ICEpower that it would have been packed properly, and that they would most likely remedy it.
It is probably a bypass for the +/- 12 V rails, judging by its location.
Jocko
Jocko
Well, I was of course assuming that the options of replacement or factory repair had been checked. But sometimes replacing a cap can be cheaper/easier/quicker than replacement/repair/refund... 😉
I didn't purchase them from ICE-power, hence I don't have the option to send it back.
I think (as sek says) that the cheapest, easiest and quickest thing to do is to replace it myself.
/Daniel
/Daniel
Cap
Yes, it is a supply bypass cap. You can even solder in a radial lead standard cap to do the job. 22µFd 25V or greater will do fine. Low ESR not needed. Actually, the unit should even run OK without it. Just may be noisy. Shouldn't oscillate though as there are small bypass caps all over the board too.
El_d said:The cap is replaced, and yes it works.🙂
Well done! 😉
Have fun with your amps,
Sebastian.
- Class D
- SMD Capacitor ICE-power
