Smartphone as source , use headphone or bluetooth?
Hi, i have an old smartphone and i want to build a full range system (as the speaker of the smartphone died)
I have a few full range (and old) CSS FR125S and i want to build a stereo system. Plus i have many LM3886 amps.
Want to know if will be OK to connect directly to the headphone jack or will be safe if use bluetooth.
Plus will be great if someone know some good designs of small systems like the one that i want to build!
I've been looking around for detailed specs, but even the user manual does not state which bluetooth version it has.
Newer BT versions have quite good audio quality, and it may be well worth it to avoid a potentially noisy jack connection.
It's quite common that there's a fair bit of noise on the jack if there's no music playing, you might be better off trying to find a wifi dongle. But that would also add to costs.
Some people use soundwire to stream music to old phones, then the phone would more or less be converted to a wifi dongle/receiver of sorts.
GeorgieLabs
