So I got my Alpairs 5.2 while waiting to buy the new Alpair11MS and since it's my first time seeing a full range driver I decided to plug them in.
I used the super powerful (for a headphone amp) Dynahi balanced SuperSymmetry designed by kevin gilmore to power them, I hacked an ethernet cable (8 cables turned into 4) and recycled an XLR to 3.5mm adapter I wasn't using.
first impressions: they sound like loud headphones sitting on a table. so I decided to put them in an amazon box, but I didn't have a matching set, what I did have is paper cups
So I shoved the drivers into the paper cups and it sounded better, some type of low end was now present .
Since I also ordered wool stuffing I thought I would play around with it. I cut a small venting hole at the bottom of the cups and filled them with wool stuffing.
Well that actually helped a bit everything was a bit more defined but it still sounded terrible of course.
The highs were to be receeded, the midrange sounded like a can, the bass was barely present.
but the speakers did certain voices REALLY well. and the imaging and soundstage was incredible.
It also effortlessly filled my small room with sound.
I'm making a pencil for them on Sunday, I really hope it completely transforms them. I have been using headphones for a while so I'm a bit spoiled on detail and clarity.
of course this doesn't really qualify as MLTL (or does it ? haha) it sounds like crap with it was fun taking the 10minutes to make
The paper cup is kinda small, and can we assume they have very low hours on them? We usually don’t even bother listening until they have a couple hundred hours on them.
Do you mean a Pensil? There is no Pensil for these olny the Giraffe ML-TL.
http://wodendesign.com/downloads/Giraffe-A52-MLTL-0v99-081015.pdf
Bass will improve dramatically and mids will open up since they won’t be claustrophobic.
I’d suggest using just a single pair of the CAT5 strands. Is it solid (good), or stranded (not as good)?
dave
dave
ok I'll leave them plugged in for a while, but not on my class A amplifier hahaThe paper cup is kinda small, and can we assume they have very low hours on them? We usually don’t even bother listening until they have a couple hundred hours on them.
yep that's the one, I'll use a CNC to make it, do you know the board size I need ?Do you mean a Pensil? There is no Pensil for these olny the Giraffe ML-TL.
Shaper | Origin
it's stranded... I have fancy speaker copper cables I'll use once the speakers are broken in and in their Giraffe boxesI’d suggest using just a single pair of the CAT5 strands. Is it solid (good), or stranded (not as good)?
dave
ok 15mm ply it is, thanksWe built Girrafe out of 15mm ply, but 12mm would work. 18mm would too but is overkill.
dave
quick update, I space the wool apart in the cups. and EQ'ed the speakers.
the sound is now very impressive. balanced fairly clean and detailed and enough bass .... do never underestimate the power of a good EQ
Are you aware of the Mark Audio recommended break-in procedure?
nope
The breakin procedure was only ever in the Mark Audio forum i believe.
Slow & steady break-in with a slow ramp-up in levels over th e1st 100 hr with breaks every 4-5 hours.
I start with a couple hundred hours of low-level FM radio.
dave
this seems very involved, I feel like the manufacturer should do that themselves. I don't mind paying extra for it ...
2 strands pulled from a CAT5 cable. Use the same colour each side (each pair has a different twist rate).
You can take it further… there are a couple ways to do that.
As to the break-in, it is not that onerous, all speakers need it to some extent. Mark has addreesed this specific issues, the new A7MS/A11MS claimed to need much less break-in.
After the 1st 20 Hrs or so, the worst is over, and you can just enjoy them (althou at lower levels) for the next 80 hrs or so.
dave
dave
Dave, thanks for the info on the Cat 5. Just so I have it correct:
2 strands for + side and 2 strands for the - side of each speaker, both the same color (total 8 wires.)
or, do you mean just 2 strands the same color used on right and left speaker (total 4 wires).
I have read various threads on diyaudioprojects website, so yes you can take it further.
Myles
Myles
I just made those. I filled it the boxes all the way to the top with wool
it was a good learning process, trying with and without wool, open or closed ect ... they now sound VERY GOOD.
they're just a bit slow, & lazy (compared to my electrostatic headphones... )
I'll keep playing with them to see if I can get a more tighter midrange.
- Full Range
- smallest & cheapest MLTL build
