Smaller Leach Amp V1
PCBEXPRESS - 75 pcs $1181, 100 pieces $1485 - 3 days
PCBPRO - 2.5 oz copper, add $200 to lot price for engineering review (price per board less shipping and tax)
Delivery 5wk 4 wk 3 wk
25 $21.70 $22.25 $25.59
50 $14.29 $14.65 $16.85
75 $11.82 $12.12 $13.94
100 $10.58 $10.85 $12.48
250 $8.36 $8.57 $9.86
The $5.00 per board differences can be use as postages.
Global Priority Flat Rate Envelope $9.00.
There should be saving realized if made in US.
But it is only 2.5 oz copper compared to the 3 oz, how thick is the board?
There are currently 48 boards for US & Canada.
I just used their standard settings to get an instant quote. .062" thick boards. I also had inadvertently selected V-scoring - individual boards are less expensive -
Pricing before $200 lot charge
5 wk 4 wk 3 wk
25 $15.26 $15.65 $18.00
50 $11.07 $11.35 $13.06
75 $9.67 $9.92 $11.41
100 $8.97 $9.20 $10.58
250 $7.72 $7.91 $9.10
.094 thick boards add about $1.50 at 25 pieces, $1 at 100 pieces
I suppose we should decide if there is enough interest to get a formal quote.
JensRasmussen said:
I will be making a small update later. It has to do with the silkscreen, I have found that some of the text should be drawn using a bigger font.
I will report back when the data is ready
\Jens
When you are at it, try to have all deginators visible when the part is soldered (practical when troubleshooting and service). Remember also to add extra polarity markings if necessary. Have you check how I have done the marking for caps? I have done a "stripe"(minus) and put a plus sign outside.
If the part is squeezed in you may use some line to point at the part. Check R20 and C7 in the picture.
Maybe add test points or at least a point for ground.
5 wk 4 wk 3 wk
Will you take care of the group order and handle shipping, you are most welcome to do so as I'm pressed for time at the moment.
\Jens
OK, I'll do the group buy. When Jens posts the update mentioned above, I'll get a formal quote.
I will ask for 2.5 oz .094" thick boards in green - other colors add $1.50 or so to the board cost. Does anyone see a need for a red or blue board?
Payment will be paypal from a bank account. Do not send money yet.
EDIT: I just checked what I could without registering for a sanity check -I'll check advanced as well, thanks PM.
Did you get a quote from 4pcb/advanced circuits? Mark and I have have found them to be the best price so far for our Krell boards.
Bob Ellis,
When the final version is posted, why don't you try Al Pinkymouse suggestion.
Maybe we can get the student discount too. Heh, finishing my master. So still have an .edu email. It said get the quote first, then call them about the student discount.
