Small tubes with the nicest glow. What is cheap and easy?
Behringer was heavily critized for putting orange led behind mic tube pre. Lots of people disliked the gimic.
Cause it looks horrible! Don't do that!
You could use normal ECC83, easy to get. But prices for these also doubled and they don't glow too bright.
I would probably hunt for some old, defect tube gear on the 2nd hand market and take whatever you find in there.
I can understand why some people don't like blue LEDs, but orange? Orange LEDs under tubes really do look like natural glow to anyone who isn't an actual tube geek. Just buy the cheapest tubes you can find (Chinese 6J1? TV tubes nobody ever wants?) and stick an orange LED under them. You can make the glow as soft and subtle or eye blinding as you like. Average Joe won't be able to tell the difference.
(I was watching All The Light We Cannot See on Netflix the other day and there's a transmitter that clearly has some uplighting under the valves to make them more 'tubey' on screen. Only nerds like us know)
The heaters will last surprisingly long. Not good for the rest of the tube, but if it’s just for the light show it wouldn’t be an issue. Only problem is the 6 volt versions tend to be expensive. It’s the 21, 26, 36 volt versions that are cheap. And then you have to double that to light it up like a Christmas tree. Maybe instead of a pentode, go for a big damper diode with a top cap. They look pretty mean, and tend to run lower prices because nobody wants them.
