Small fullrange bookshelves
:eek:Hey guys, I've been lurking here for some time but had never tried to build anything HiFi. Couple of months ago I built myself a pair of sealed enclosure, pseudo 2-way bookshelves with a small vented sub, driven by a tiny valve preamp and a tiny power amp fed by a tiny DAC :eek:. I've been quite happy with these, very surprised by the way they sound. Some weeks ago I bought a 2.1 system for next to nothing because I knew I'd want to take a second try at DIY.
The drivers seem quite beefy for their size, the magnets are heavy and the driver suspension seems like it would allow for quite some throw. Anyways, I was thinking to try and build a pair of full-range bookshelves with these, a TL or BLH, not sure yet. Actually that's why I'm here, I wanted to ask you guys if you recognize these drivers, or at least the brand/model. I took a look at some diy speaker sites like diyaudioprojects.com but I'm not sure if any of the designs could be adapted to the drivers I've got. Drivers are 7cm in diameter or about 2" 4/5. Any ideas/insights/tips are greatly appreciated!
Cheers!!
If you not aware free program REW can measure drivers T/S specs, there after free WinISD can simulate optimal box. If not tried it before will need some exercise to educate your self for most mean 1/2 to couple of hours. Use search to find programs and use their build in help guides or search web for more guides. If you at least get the T/S parameters sorted out then would imagine some helpful members would gladly design you a optimal box.
