Small class a amplifier project
DOZ, Death of ZEN is a Class A amplifier at ESP Projects
Death of Zen - A new Class-A power amp
The test circuit used by Rod Elliott is a very basic Class A with resistor loaded output ( 8 Ohm ).
This schematic shows +24 Volt supply.
But it will actually work without problems at lower voltage, too.
And you could very well use other transistors with good results.
Just released yesterday, an idea by Mike Renardson (end of page) :
HEADPHONE AMPLIFIER DESIGN, PART 1.
yeah, but as neither of the circuits at the end of the page are proven it might not be good for a first go
the author states:
"Here is an untried version with component values"
"This circuit could also possibly work as a low power class-A amplifier"
Anyhow another simple option might be something that doesn't even require a pcb - just use point-to-point wiring.
for example:
http://diyaudioprojects.com/Solid/ZCA/ZCA.htm
