Slimline 2U chassis
Hello! I am looking to purchase this Slimline 2U chassis and was wondering if I can get it with a 3mm aluminum bottom? It is the size I need and I am guessing that I would have to make the cutouts for speaker binding posts, RCA/XLR, IEC, etc.
Another question is when I select the Depth to 350mm with aluminum covers, I notice at the bottom it is showing 1mm steel for top and bottom cover? Is this correct?
By bottom do you mean the bottom cover? Or do you mean the rear panel?
If you mean bottom cover, yes, just select the "W/Aluminum Covers" option.
If you mean the rear panel, the answer again is yes, just select the "W/Aluminum Covers" option. Please note that if you choose steel covers, the rear panel will also be steel.
That would be a bug. Thanks for reporting it! I'll fix it.
