I don't understand what this waveform in the attached photo is telling me.
It has a significant dip in the top before it pulls down. This bank is heating up with a 2ohm limiter but i do have the fets clamped similar to what you have recommended in the past with a binding clip and an old clamp from a kicker.
Its taken from the Gate of IRF3205 Q16A. It drives the transformer that has the additional winding for the 15V regulators.
The probe is grounded to the source leg.
Photo #2 shows the waveform I am seeing on the gate of the other banks driving different transformers.
I spoke to soon. I checked the waveforms on the transformer windings going to the rectifiers. The bank is still running hott i think. The transformer is putting out 75v AC. The other banks are 73 and 72v ac. I checked the other side and all transformers are outputting 72v ac. I dont trust my sense of touch im going to use a thermal image camera to confirm.
Should all the AC voltages combined at the rectifier be the same?
Lesson learned all that time spent because i was too lazy to use soldering wick and an iron. I only used it for removal never had any regard for the surrounding parts. Definitely was the hot air gun i want to throw it in a bin and not touch it.
I am down to 1.2amps idle current from 1.8amps and power section running smooth.
I don't have the confidence yet so i like to have you walk me through things and go back and read up.
Thanks again Perry.
Thanks again Perry.
- General Interest
- Car Audio
- Skar RP4500 waveforms
