Skar RP 2000.1D In Protect
Hi fellow social distancers, Got two Skar RP 2000.1D in for repair. Both in protect. Power supply runs. No shorted outputs. Pulled all the outputs to see if it made a difference. No change. The protect circuit is controlled by a 393 comparator chip. Just to be sure I changed the 393 chip. No change. Can anyone shed some light on the protect circuit in these amps? Thanks
LM393
Pin 1: +5.2V
Pin 2: +5V
Pin 3: +8.5V
Pin 4: Gnd
Pin 5: +2.5V
Pin 6: +2.2V
Pin 7: +5.2V
Pin 8: +14V
Perry, thanks for the education. I've attached pics of the output wave forms.
I just needed to know if there was activity there.
It looks like your probe may need to be adjusted to match your scope.
Have you tried operating all of the pots and switches through their entire range to see if audio (or anything else) played through?
Was there any modulation of the rail-rail oscillation when you drove a signal into the amp?
Okay,
"It looks like your probe may need to be adjusted to match your scope." I will look into that.
"Have you tried operating all of the pots and switches through their entire range to see if audio (or anything else) played through?" Yes
"Was there any modulation of the rail-rail oscillation when you drove a signal into the amp?" very little if any.
New information. I only get rail to rail oscillation if the signal ground is isolated from power ground. When common ground I get no rail to rail oscillation. Protect light stays on either way.
