SKA AMPS GB150 kits/complete build
Gareth, I wouldn't mind getting a couple of your boards. I'd been thinking of a dual amp setup for a passive line level crossover and they'd make a nice match for my SKA.
I recently re-read that GB150 thread discussing Jim's boards and was reminded of your effort.
EDIT: Hmmm, maybe your TGM8 might be better! I've just had a look at that thread...
I see so engee is Gareth.
:fim:
The amp is thermally stable by design, it’s only the physical construction that could be the issue. A decent sized heatsink is still a good idea. My version is slightly different as those diode wired transistors are not required. In my version the heat sensors are mounted directly in contact with the power devices in a compact arrangement.
Picture?
