So I see winISD modeling gives frequency response model up to about 200hz . If I am looking to make a box for a regular bookshelf speakers which i don't expect to play sub 100hz frequencies will the sound signature depend on size of the box?
Is it correct to assume that box size is really to optimize bass performance
Yes/yes, or more correctly:
T/S theory peters out at the driver's effective upper mass corner [Fhm] = 2*Fs/Qts'
Qts' = Qts + any added series resistance [Rs]: HiFi Loudspeaker Design
GM
This is a little too complex for now) need to set aside time to read.
But just to eliminate standing waves what are general proven ways to help that.
1)most suggested polyfill and put lots of it
2)egg crate foam not recommended. I've seen them used together with polyfil on many bw 600 series speakers
3)some manufacturers route cuts along inner speaker walls . Polk audio did it on their nicer sda speakers made in 80s. Not sure if this is helpful
