SIT Startup Problems - What did I miss?
Hi Dan,
we are mostly used to the capacitor free outputs and check the offset.....
I was in the last days also in the situation to be in panic with the F3 clone and my newly implemented 15 x 1000uF Silmic ... it is easy to forget what ilimzn wrote...
especially when building a new project.....! 🙂🙂
but what was the reason your SIT was blown?
🙂 do you have some improvement with tons of parallel caps instead of one of 15000uf with 15uf MKP decoupling?
🙂 bonne année too.. for the output coupling or source resistor bypass i have very sweet sound with mundorf M-lytic AG and 10uf clarity cap decoupling , sounds better than Epcos skiorel or evox rifa 🙂
i have heard than the more parrallel caps the less ESR but increase insertion loss ( angle de pertes in french)..
After a couple of little bumps in the road my SIT is up and running. Still needs a little cleanup and more paint but should have some listening impressions soon.
Dan
