Presenting thread here: SissySIT R.3
Schematic and pcb screenshot post #1 , plenty of pictures after .
Tips and Tricks thread - will open, sooner or later
Reading entire thread is advisable , same as inquiring any technical question there : Be sure that you are aware of all things electrical and mechanical !
THF51-S still available on fleabay , watanabetomoaki confirmed seller , also pras1701 - being member here
instead , 2SK182, 2SK180; anyway, everything in linked thread
Pcbs are made for UMS , mounting directly to heatsink
Do not hurry - read , think , ask and only when you feel that you want it and can make it , proceed ...... advice which I'm finding applicable on practically anything .
For anything else , write either here , send PM or directly to >zenmodiyaudio@gmail.com<
Prices are mostly dictated with small scale nature of operation (as always is case) and time/work involved in matching and soldering little buggers.
For ordering , contact me at above written e-mail addy .
Kit options :
Option 1.
- LCH pcb ,
- RCH pcb ,
- all smd buffer JFets (Toshiba 2SK2145BL) presoldered ,
- smd precision CCS chips presoldered
- all smd caps and resistors presoldered ,
- 4pcs of 1uF MKC caps (for important bypass positions) enclosed.
Full price , including Paypal fee and P&P for registered shipping all around the Globe - 135E
Option 2.
- LCH pcb ,
- RCH pcb ,
-all multiturn trimpots
-output P channel mosfets , 2 pcs , IRFP9140
-cascode bjts
-optocouplers
-all electrolytic caps (all Panasonics ,except Elna Silmic II for one signal route position)
-one-pin sockets for special resistor positions
-all (MF 600mW) resistors
-T0220 heatsinks - 6 pcs
-etc.
to recapitulate - everything what goes on pcbs , excluding signal xformers and pcb/mosfet mounting screws/nuts/washers and , of course , excluding THF51-S
Full price , including Paypal fee and P&P for registered shipping all around the Globe - 185E
If I have everything in drawers in moment of order , can ship in a week time;
If I don't have any of normal parts in drawer , shipping could be delayed up to 3 days;
If I don't have pcbs in drawer , shipping could be delayed up to 2 weeks;
If I don't have most critical part for getting in my neck of wood - CCS precision chips , shipping could be delayed up to 3 weeks.
All in all - you all know that ZM is slow, but inevitable
Handy Addendum (in short : HA!):
-Cap Bank pcbs - set of 2pcs; dual rail, CRC (pads, if you want differential CLC), snap-in up to 35mm Dia, resistor and pads for LED, position for 10mm NTC connecting Audio GND to chassis;
-NTC pcb/ FW style Soft Start - set of 2pcs; each having place for 2 independent NTCs;depending of arrangement of primaries of Donuts you're using. you'll need either one pcb for two Donuts, or one pcb per Donut
HA! set is 25E more
see pics for HA!; lazy to search do I have photo of NTC pcb, but who cares
Kit options :
Option 1.
- LCH pcb ,
- RCH pcb ,
Option 2.
- LCH pcb ,
- RCH pcb ,
-cascode bjts
-optocouplers
-etc.
HA! set is 25E more
I sent mine too. This should be a great project to work on while awaiting group 3 of VFet amp kits.
I will take option number 2 and the capacitor option as well. Email sent. Thank you zen mod for your hard work and fabulous contributions!
Boyz, cope with me this first week, if you're not getting reply/confirmation of Paypal, etc.
Things are overwhelming and I'm only one ( not Only One as you know who).
Thank you.
Thank you.
I'm having a hard time deciding which kit to build. I'm equally tempted by the SissySIT R3 and by the Old Soul. Seeing how rails and most of the components are shared - how about I build both in the same chassis and switch from one to the other? How would you recommend doing this? Switch the rails+signal from one set of fully populated PCBs to the other set? or find a way to put in a switch after the JFET buffer? or maybe after the transformer?
Boyz were doing that in few logical ways:
- one PSU case, separate amp cases, combined and used by choice
- one case containing one PSU and two amp sets, power lines (DC) being switched in some convenient way ( separate fuses in rails, faston connectors, etc.) while each amo having separate in/out connectors
first way certainly giving most flexibility
I can't give you recipe by my preferences - I don't have them - having few "Do Not Touch!!" amps, while all others being temporary guests on T-Bed(s)
It seems I got bitten by Super PapaBug
As Mighty ZM says there are many ways to do this.
I have build one PSU box (18VAC) and connect to the amps I have using PowerCON cables
Here PSU with Sissys
Best on your build
Bob
Mighty ZM - sorry to post this in your swap post but I know if I waited for a building tips thread I would forget😉
Best on your build
Bob
working on amassing parts and following documentation
Code:
SissySIT R.3 packing list:
Resistors:
0R-2pcs
1R-2pcs
22R-2pcs
39R-4pcs
100R-16pcs
120R-2pcs
220R-4pcs
270R-2pcs
6K8-2pcs
10K-8pcs
36K-2pcs
47K-2pcs
100K-2pcs
180K-2pcs
0R22/2W-8pcs
Trimpots:
100R-4pcs
200R-2pcs
20K-2pcs
Capacitors:
1uF/100V/MKC-4pcs
10uF-22uF Silmic-2pcs
10uF/63V-4pcs
330-470uF/6V3-16V-4pcs
3300uF/16V-2pcs
Diodes:
ZD5V6/500mW-4pcs
ZD8V2/500mW-6pcs
IC:
PC817C-4pcs
LM385-1V2-4pcs
Semis:
BD139-4pcs
BD140-2pcs
IRF510-2pcs
BC546-2pcs
IRFP9140-2pcs
Misc:
1pin header-4pcs
2pin headers-2pcs
Jumper-2pcs
Needle wire conn.-10pcs
T0220 htsnk-6pcs
channel pcb set (with all SMD parts
presoldered)-1pc
HA! (optional):
Cap Bank pcb-2pcs
NTC Pcb-2pcs
Needle wire conn.-30pcs
Just to bump this up...
So, this excited greedy boy has now ordered his SissySIT kits and a pair of Cinemag CMOQ-4HPC transformers - now trying to be patient!
Wow, thanks for reminding me! I need to order some iron. Although, I might have the Jensen version - yes I do have a pair of JT-123-FLPCH. Those would work right?
I'll still probably look for cinemags though. Sad that it is easier to order for Don's in Europe, than find them listed in the US. Does anyone know if you can order them somewhere, or resort to actually calling them...
Yep yep, I emailed Cinemag to check on availability. It looks like they would be very expensive for a pair to go from California to Europe, and get shipped back over the pond to Alabama. It will depend on my mood at the time, I guess. Much less pressure since I have the Jensens.
I recently bolted a Jensen balanced to unbalanced box to my amp shelves. Using even good RCA cables Pre to Amp (~15ft) was giving me hum, more with higher wattage amps. Now with XLR cables from Pre to converter, and 2 foot RCA cables to amps, I get no hum, even with my ANK EL34 PP amp, which made me happy.
Paying attention to Zen Mod’s XA252 development, as it has balanced input option. But first SissySIT R3 + (praying) a group 3 VFET amp.
