Hi
I'm trying to create a lush and rich sound to my music.
Hence I create this common-drain single-stage amplifier to connect to my Toshiba DVD player's output (2V rms). This circuit will then output the signal to a 30K input impedance pre-amp. I found the signal from the DVD player to average around 1V.
Is everything ok with this circuit. From the graph, is the 2nd harmonic at 2.7%? I calculated it by using the peak of the 2KHz (0.005V) divided by the peak of the fundamental 1kHz (0.185V) and use this value *100 to get 2.7%.
I tested using a 1000hz 0.5V input signal.
Yes, your 2nd harmonic is at 2.7%, but it is very likely that you have far more harmonics, your circuit is already clipping the negative waves.
You shouldn't drive that circuit with more than ~250mv, with 2 volts you will get heavy clipping, not nice to hear and bad for your tweeters.
C1 is way too big, 4.7uf should be enough.
These distortions shouldn't scale with music level.
Maybe you can select a jfet with a vgs threshold below -2v.
Mike
Mike
