I want to design a DC48V single supply class D. Now, I use the TAS5630 can work normally connect to louderspeak, but if I connect the transformer to TAS5630, the TAS5630 is easy protect. I through the transformer change the voltage to 100V output to louderspeak.
Can you give me any suggestions? Thanks.
