I need to build power supplies for three amps already fitted into a single case but there is not enough room for three separate transformers. The largest amp (2x60w) requires +/- 40V for which I would fit a separate transformer/rectifier.
I know that a single transformer should not be used for the two smaller amps (2x30w each) but could I use a single transformer with each amp having a regulated power supply.
+/- 30V is needed for these amps.
The case is quite substantial and was originally built for the amps, prefilter and controls with the intention of having a separate case for the power supplies and I do not want to build another case.
As long as there is sufficient decoupling on the DC supply lines and the ground point is not compromised for earth loops, it should be fine.
Why not? Active speakers have a single transformer powering two channels, studio monitors have two amps for the same channel, and AVR has 6 or more channels
Screwups are the exceptions, not the norm, and for most people with sufficient design experience things usually work without much extra thoughts; that's why screwups happen because nobody really knows what are the exact precautions to guarantee a no screw up due to sometimes they happen and other times not providing no correlation for future learnings.
No problem with running two amps off one supply. Just make sure you get the grounding right. Where people usually go wrong is in trying to half-split the supply so they think they are going to have two different PSUs fed from the same secondary; then they discover that two things can't be both joined and separate.
You could order a custom wound transformer.
a.) two secondaries to each amplifier. Requiring 6 secondaries for the three amplifiers.
or
b.) two secondaries to each different supply voltage. Requiring 4 secondaries, two to the big amp and two shared between the two 30W amps.
or
